Re: Mariner 25HP 2 stroke
You will need to post more information to get better answers.Is the motor developing maximum RPM'S? Did you forget to pull up the anchor?:facepalm:It could be any number of things.If the engine is running max RPM'S and the boat still moves slowly,you could have a spun prop and will need a new hub installed,or a new prop.
