temperature gauge question
dbdarren
1990 mach 1 .....350 magnum mercruiser..........when i start my boat,after about 5 minutes the guage jumps to around 220 and doesn't move..up or down....what could this be or what should i check first
Re: temperature gauge question
Ayuh,... Welcome Aboard,... Check the Impeller...
cr2k
You will also need to check for any impeller parts (current or previous replacement) in the heat exchanger and elsewhere if you still have a problem after impeller change.
Brentathon
Maybe you should start replacing the word "check" with "change"?
Would ya really want to split a drive and not just slap a new impeller in? especially if there's any question on it's relation to an overheat problem?
Or, am I just too wasteful? :D
Naw,.... I change 'em pretty much Every time,...
Can't say's I've never reinstalled a Used impeller, but it ain't been very often....
But, bein' a single digit typist, there's 1 less letter in Check....;) :D
