Chasing Sunset
- May 17, 2011
- 2
ok all I just purchased a 2001 Sea Ray SunDeck with a 5.0 Murc/Alpha 1 outdrive. the problem I am having is that the trim guage is stuck in the Full up position. I know that this means that there is a break in the line that goes from the guage to the Engine. The question I have is does this wire need to be a certain wire or can I get some basic wire stock and replace it with that? I also need to know where it connects at the engine so I know where to connect the new wire. I would like to check the continuity from one end to the other on the wire to verify that it is broken but I really have no idea where is it located at in the engine compartment.
thanks
Josh
thanks
Josh
