Ok, just got done changing water pump on my 89 mercruiser alpha1. Ran it on the muffs and after changing the thermostat gasket because of a small leak I also noticed a small amount of trickle from the the shift shaft area. It looks as though there is a gasket directly behind it and that might be the culprit. And advice is appreciated.
