Picked this motor up for free, starter gear broken, spark plug wires damaged, slow idle mixture knob missing, choke linkage retrofitted, steering friction boss broken. Fixed all the above except steering friction. The question I have is should the powerhead move aft with wot setting? This one does causing choke to close, causing low power. Removed the choke linkage and now runs fine at high power. Has anyone seen this before? Thanks
