jtsaltwaterboating
- Oct 30, 2009
- 29
I broke one of my bolts attach to the motor case. As you can see in the photo now there's a hole with the broken end of the bolt still in there. The reason why I tried to remove this bolt in the first place was to clean off some corrosion off the ground wires connected to the bolt.
First Question, will I need to remove the rest of the bolt from the case or do y'all think its stuck on there to the point there won't be any other damage to the motor.
Second Question, I took the wires connected and hook it to the bolt over the one I broke off.
Thank you everyone for your response.
