The boat is a 1994 or 1995 Lund Fisherman (or at least that is what I am told; there are no model names/numbers on the hull) with a 1996 Yamaha 90hp 2-stroke. The problem is a collapsing primer bulb and engine konking out due to lack of fuel. Before you point me to other threads (which I have already studied), here is what has already been done: new primers bulbs, removal of anti-siphon valve, new fuel pick-up tube, and replacement of fuel hoses. The problem occurs only when the fuel tank is half full or less. I.e., everything is fine with more than a half tank of gas.
My guess was that there was a problem with venting for the gas tank. But I figure that would be the case regardless of the amount of gas in the tank. A quick visual check of the hoses that appear to be for venting didn't reveal anything: the hoses look to be firm and not pinching anywhere. I say "hoses" since the vent hose runs from the filler tube to the tank where it tees to become two hoses, each attached to the tank.
It does not seem to be a fuel volume problem. It takes about 5 minutes on the main motor under full throttle to collapse the bulb. The bulb will also collapse after about 90 minutes of trolling on the 9.9 hp kicker. And, as noted above, the problem does not occur when there is more than a half tank of fuel.
My next step is to remove and inspect internally the vent hoses. Maybe one is partially blocked. I really doubt I will find anything there, but I don't know where else to look. Has anyone had this problem? Even if you haven't, I would really like to hear some ideas or comments. This is driving me nuts
