gumbydavid
- May 1, 2011
- 1
My 97 johnson SPL 90 loses power intermittently. Carbs are clean. Compression approx 115psi. New Plugs. Cleaned the recirc valves. Ran tuner in the engine last week. It helped with the idle. It ran fine for most of the trip Saturday until I began back. I could not get it on plane. It didn't have a noticeable miss or cut out. It was just a reduced power. The reduced power level was consistent. It did not hunt or fluctuate. I pulled the cover off in the water and removed each plug wire individually and would throttle up with each removed. A miss was noticeable and it would run worse with each wire removed. When I got home I checked the plugs. Three were clean. One plug had some varnish. It was not wet. I decided to pull a head. I am very concerned with the amount of piston to cylinder spacing I found. I could measure approx .030 between piston and cylinder and there was a little scoring. The engine doesn't seem noisy. It has good power most of the time. Could the piston slack cause a power drop like this?
