45hp classic 50 water leak at #1 plug
danmar
happy to say the 45 is running,good stream at taletell, 1/8"hose midway between plugs flows water. BUT water is seeping somewhere in the #1 plug area cant find visible crack, pulled plug no water in cyl. best i can tell. pulled plug wire while running definitely firing.. im guessing the cover is cracked any other thoughts from your experiances thanks danmar
