Compression update/ ?
Status
Not open for further replies.
archerobx
I tested 3 out of 4. got 120, 121, 120.
I couldnt get it into the 4th.
Questions:
Can I just buy a elbow and screw it in to test compresssion or is there a trick I am missing?
Do I need to check it since top 3 seem good?
thank you
Ryan
M
Maxz695
Guest
Re: Compression update/ ?
yes the elbow will work may need some teflon tape to make a good seal I heard a post where the guy drilled a hole in the cowel to get to it I wouldn,t suggest that He had a plug for it when he was done
JB
What engine and problem are you talking about, Ryan?? If you are updating a previous thread you need to do it with a reply to that thread, not by starting a new thread in the middle of a conversation.
http://forums.iboats.com/showthread.php?t=250877
Status
