Problem with a 115 hp 2003 efi Merc 4 stroke can't increase 4000 rpm at top speed.
Remdub
Can't increase 4000 rpm at top speed. In the driveway everything is fine when it is in the water that is what happen.It looks like the engine is nmissing some fuel. I checked all the small things like plugs filters all new . Is anybody ever have the same problem reply please have a nice day!!
M
Maxz695
Guest
Re: Problem with a 115 hp 2003 efi Merc 4 stroke can't increase 4000 rpm at top speed
does the engine sound strained when at WOT? is it miss firing?
Faztbullet
Check your spark as it can run fine on 2 cylinders in driveway and rev up fine with no load on it. If engine runs up to 4000rpm and goes no further you could have a fuel problem from the following: low fuel pressure from high pressure pump, low fuel pressure from mechanical pump, clogged/stuck injector/s, restricted fuel supply from tank. If it is missing spark on #1 and #4 or #2 and #3 they are on same coil, so it could be a pulsar coil in flywheel...
