johnson 300 bearing housing removal
loki76
hey guys was wondering if i am missing something- i have tore down several lower units but am stuck on this one-it will not budge- is there a secret or trick to a v8 lower unit-
loki76
Re: johnson 300 bearing housing removal
1993 johnson 300hp 30"shaft- counter rotating
boobie
To take the CR g/c apart first you remove the two retaining screws and keepers that hold the prop carrier in. Then put some washers on the prop shaft and then the prop nut. After that get a big slide hammer with the right jaws and pull on the prop shaft. This brings out the prop shaft carrier, fwd gear and ect. You may have to apply heat around the p/s carrier area of the g/c. Don't try to pull the propshaft carrier out as you do with a std g/c as you will screw up the insides. Would highly recommed an OEM factory service manual to do this repair.
loki76
thanks man- got it apart and forward gear is missing teeth-the cheapest gear set i can find is 800 bucks plus seals clutch dog etc. i am going to be in over a grand-thinking of looking for a whole lower unit-bearings look good but alot of money on an old gear case-if i do rebuild is there anything above the normal i need to know-these v's are alot diffrent than what i am used too-again thanks for the help-
boobie
Is this a twin mtr rig? If not try ShopSEI.net and put a standard rotation g/c on it. If you try to rebuild it, you'll need some special tools plus a shim gauge tool to do it right. I'd look for a used g/c.
