First time this year possible to go boating and fishing with my nice classic boat and unfortunally it FAILED.. 2-3 weeks ago I've run my motor in a big barrel to check if everything seemed to be ok and it did. Just had to replace a fuel pump filter cork gasket because it was leaking out while priming the gas line bulb.
I get at the lake today, engines starts pretty fast but stalls fast also. Ok it's cool out so I re-try leaving the choke a little longer. Nothing to do it still stalls choke on or not.
What I could see is that it's way to rich, I've seen full of gas at the surface of the water. I got it running a low speed a little while but rough. I've disconnected the fuel line and once it had less gas it finally ran good but ance it ran out of gas it stopped again.
What could be the problem?, I have a service manual of this specific o/b and it's not the first carb that I rebuilt? It has a new float also. The carb did soak in carburetor cleaner for a few days before re-assemble.
Thanks for helping me
