Fuel sending element
sergeant0018
Does anyone know the size of the fuel sending element for a 1998 Aquasport 225 explorer with a 102 gallon tank
Silvertip
Re: Fuel sending element
Fuel senders are pretty generic and some are adjustable for length. Pull the old one and measure its length. As long as the mounting flange is the same only the length remains and issue. And before you replace it, make sure it is actually bad. It should measure 33 - 240 ohms as you swing the float arm through its range. Disconnect the sender wire when making the measurement..
Solittle
Look for the data plate put on the taank by the manufacturer. It is usually near the sending unit. Contact the manufacturer and buy the sender specific for your tank. You should get a more accurate reading than by buying a generic.
