Miami Mark
- May 14, 2011
- 2
I have a 2006 Mercruiser 5.0 MPI, ser# OW381688, with 288 hrs. Last weekend the audio warning and check engine went off while I was running. The audio was two beeps every one minute and the check engine on the gauge stayed on. When I got back to the dock the engine would not idle. After reading some threads it sounded like the IAC went bad. I ran the boat the next day and when I got to where I was going the boat idle perfect and ran good the rest of the weekend.
I do not have a scanner but have order an IAC. My concern is when I replace the IAC, assuming it is the IAC will the audio warning system stop beeping and will the check engine go off on it?s own or will I have to reset the code.
Any help will be appreciated.
