1976 Evinrude 135 - TILT & TRIM limiter plug/switch halfway up hydraulic cylinder???
Requesting any assistance I can find on a fix that went terribly wrong today...
On one of the hydraulic cylinders for the T&T is a plastic plug/limiter switch(???) that screws into one of the hydraulic cylinders about halfway up, with what appears to be a ground wire attached to the opposite end of the plug that is not screwed in.
For some time this little plug has been leaking hydraulic fluid, so today a friend and I attempted to take it out and and fix it... When we unscrewed it (kinda hard since it's on the the side of the cylinder facing into the stern of the boat), it looked fine... as if over time it had just worked its way out. When we cleaned it, added some RTF silicone and started to screw it back in... with hardly any force, after about 3 turns, the entire plastic plug sheared in half!!!
So, my buddy and I were left with some type of plug or limiter switch with a tiny ball bearing in the center that was broken in half. We're guessing it's for the T&T guage or control switch on the dash, but we don't know... Heck, we don't even know what it's called!
So we're trying to figure out:
A.) What it is and what it's for?
B.) And if we can get a replacement part such as this - is this a standard type of plug/limiter switch used in other motors? Or do you have to find a complete replacement cylinder with the plug/switch already in it?
C.) Where the heck we go from here...?
I can't tell you how P'OD we were, since we were just talking about plastic breaking when it sheared in two... Any help would be greatly appreciated...
