9.9 with no spark
jolineandlarry
hello to all. i have a 9.9 force model# 92f7a serial# 1742. appears at one time woodruff key broke and was replaced,coils were damaged and not replaced. is there anyway someone can help me figure out the year of the engine? will baseplate and coils from a 73 chrysler 9.9 interchange? appears everything is the same except the throttle plate but could be swapped out with mine by removing four screws. thank you larry
roscoe
Re: 9.9 with no spark
model# 92f7a
1987
Welcome to iboats Larry.
Sorry, can't help you on the swapping parts question.
jolineandlarry
Thank you so much for your help. Atleast I have a starting point now. Will do some more homework on the interchange of the baseplate and coil issue. Thank you again, larry.
