Bought this a month ago, started it up in a garbage can full of water. So after I replaced the impeller, + leg oil which were fine. Then again restarted it again in a garbage can, all seemed fine. So took it to lake and launched it for first time and would not start. Brought it home and when gas squirted in cylinder it fired, so changed the gas pump diaphram + check valves, and put in carb kit. Now after getting it back together yesterday I have no spark.
After reading in the forums I seen to remove salmon (orange) wire from the switch box to see if spark returns (which it didn't) and to check if voltage was present on this salmon wire with key on ( which there isn't.) My question is what would be the correct sequence to trouble shoot backwards to find my problem. One other thing I noticed is that the little box called the rectifier with 2 yellow wires leading to it from the stator is looking like it has been very hot sometime before I bought this boat and with all the moving to get to the carb one wire is a little loose but the holding nut is rusted on and unwilling to tighten as it wants to turn the bolt inside the rectifier. This rectifier looked this way before when I started the motor in the garage but now the one wire is a tad loose.
Any help would be appreciated as the nearest dealer is 80 miles away and $80 bucks a hour.
