Re: Keel Repair
Re: Keel Repair
Something took a bite out of the lower leading edge of my fiberglass encased lead keel. See photo. No damage to hull/keel joints. Need help on what to use to replace the plastic or foam material between the lead keel and the fiberglass skin. The material is very hard and dense.
View attachment 93981View attachment 93980
All suggestions appreciated
Sorry..this time of year with Launching and colder weather has been Crazy with me
Okies.. took a good look at the damaged keel.
Your SURE your Keel bolts are good and not leaking right ??
No water in that Foam from your keel form ? ( You cannot layup glass when you have wet foam ).
Looks to me that they had a keel made up..bolted it..put into your glass form then Poured foam in there.
Its all Cosmetic Basically for your keel ( Not as bad as it looks kinda thing ). IF YOUR Glass Is intact !
No water should be in there before you foam and glass.
You can use basically any " foam " for a " form " then grind and glass your lead in.
You have to do things in reverse from the factory.. instead of glassing..then put keel in..then foaming it in solid. .. .. You have to remove the bad glass and foam ( which only holds the water out of the keel form ) .. re-foam for shape and then re-glass the skin of the keel ( probably no more then 1 layer of poly 1.5oz mat .. 1 layer of 1708...then final layer of 1.5oz mat. ) You Might get away with 1.5 oz mat for All your lams.
Need How they put this lead in the boat though.. open it up a bit more.. ( not crazy open..just enough to know what your dealing with ).
I think you will be ok without busting the bank on this
YD.
