Re: Anodes
You know that is a good question, I don't know but usually the port engine will be a counter rotation therefor off setting the starboard engine torque. The thing I like most about outboards is that if you are at a marina you can tilt your engine all the way out of the water. This is when you can find the worst case of electrolysis, charged particles that attack metal, and have heard stories (never seen) of how an anode was visually dissolving like an alkaseltzer tablet. So it helps with corrosion to a certain point and should be replaced when about 2/3 gone.
