I was out on the lake fishing today in my 374v Ranger with a 175hp 2.5L XRI and I ran it about 5 minutes at 55-60mph and then slowed down and idled into the cove I was going to fish in. I am always looking back at the motor to make sure its pumping water and after the hard run I looked and it was peeing water just fine. So I idled around and after about 2 minutes I heard some hissing and spitting and I turned around and the motor was just spitting water out like it had air in the lines. It was just like a garden hose does when you turn it on until the air gets out. Motor wasn't hot that I know of because the warning buzzer didn't go off. So I put it in neutral and revved it up to about 2000rpm for about 10 seconds and it cleared up and then did just fine the rest of the day.
What could've caused this to happen? Never seen this before. Is this possibly the water pump getting ready to bite the dust? The person that owned the boat before me changed the pump 2 years ago and the used the boat for a year and then it was parked for a year. This motor also has to run for about a minute before it starts peeing water when you first crank it up after its cooled off. I've been told this is the nature of these motors since the water goes through the motor and thermostats before it ever goes out the pee hole so the thermostats have to open up.
