Bennett trim tab problem (Tabman II)
psherwin
Tabs have not worked on my '86 Correct Craft Martinique since acquired. But now, after going head-to-head with the top of an 'ole sweet gum tree in an Arkansas lake(and losing out), I have addressed the trim tab problem; hydrollic pump engine just goes "click" and no action on any function. I don't believe te unit has worked for years and that it was submerged for a while.
Tabman
iboats.com Partner
Re: Bennett trim tab problem (Tabman II)
Psherwin,
Let's see if the pump motor runs. Make sure that the black ground wire is making good connection to negative 12 volts. Then put 12 volts positive on the yellow wire right at the pump. If the connector looks corroded cut it off and put the power to bare wire. You should hear the pump motor spin when you do this. If you hear it let me know and we can troubleshoot the system.
If you do not hear it spin, it's time for a new unit.
