Re: Stuck driveshaft on rude 9.5
Well I wrote a complete break down of how I got mine out and it said that I wasn't logged in when I posted it, so I'll try again in short form. I used an old lifters weight and drilled a hole in the center that would just fit over the shaft, below it I put on a couple of wire connectors for large wire that bolt together (2/0 or so) and used the weight as a slide hammer. Make sure that you mount the clamps where there are no bearings in the lower open shaft area and brace the power head so that it can't move. Don't get carried away and break anything.
