1968 bayliner mercruiser overheating
peewee014
what can be the causes of my 1968 bayliner mercruiser to overheat. i just replaced the manifold; since it was cracked. any suggestions of what is causing my boat to over heat???? :confused:
BIGALF
Re: 1968 bayliner mercruiser overheating
How is the water pump? When did you cahange it last?
Bt Doctur
dont know about the boat overheating but the engine will if not enough water is getting in , circulating properly or water not getting out.
Bt Doctur
Well, if you don`t say WHAT IT IS, we can only offer a best guess.
searay3
raw water pumps are the first place to look for overheats.
