I have a 1975 Johnson 9.9 hp. model# 10R75C. last year it ran fine & pumped good stream of water, this year on test run it only spit water, I could feel air pressure at hole when I stuck my finger over hole while running it, good air pressure coming out bit just a spit of water & it was hot. been reading other posts about water problems, does mine have a thermostat? figured they all might have but read somewhere that my yr doesn't. where is the thermostat? going to try the weedeater string through hole & air compressor to. any suggestions please??? thanks
