Re: merc 115 tilt troubles
Thanks for the post. I will contact the customer with this info. So this problem can cause almost an immediate failure? I assume this design is faulted, is there an alternate unit that could be used? Thanks, Tim
the rust can build up until the spring no longer has enough strength to hold open valve. The failure builds gradually but you don't see anything until it crosses a threshold. Every marine hydraulic system ever made has this flaw. The only way to stop it is to mount the actuator in a dry location. Most systems would have a hose loop or J trap for the water to collect in when the system is stored.
NO big deal. The Merc system goes 15 yearsand has a way better trim motor than most. Look at your picture. That trim motor is almost 20 years old and still going. The cost of a motor is often more than the cost of a hydraulic rebuild. So, it's a wash. Actually, maybe not a wash. Mercury trim wiring is the best in the business - not only the most reliable but also the most affordable. Best in both. At any rate, it won't cost you more than $250 to fix it no matter what. An alternate is going to set you back double or more.
It looks identical to mine, which is a 96 Merc 115. That top shaft seal isnt available anymore, so if it the cylinders shot the only part Merc sells is the whole unit, which of course is insanely priced. Ive been looking but havent found the seal available anywhere in the aftermarket.
I saw the seal on a parts diagram only a few months ago. It may still be available but the trick is finding the part number. There are hundreds and hundreds of engines & serial number combinations that use the seal. It remained unchanged from 1987 to 2010. If all else fails I sell a seal kit listed on ebay but it may not be the exact parts you want. It's a one size fits all thing.
