boat want crank
john farmer
got a two thousand evin, johnson ram injected. started it up after winter was running good in the barn had water to it , and it shut down with my check engine lite flashing want do anything now ,its got it completely shut down got power to the control panal on the dash but no power anywhere else want even try to start , the check engine light just flashes.
boobie
Re: boat want crank
First off, check all your battery connections on both the battery and the mtr for being clean and tight. Next check all the fuses in your pdp panel.
