chippewa26
- May 11, 2011
- 2
I had just bought a 79 Crestliner with a OMC 140 and I have noticed when I run the engine wide open on the water, I am ok, but when I stop and kill the motor, then start it back up after awhile, I get water filling the crankcase. Normally if will fill about a quart over or so. I have a end plate cap on the front of the exhaust manifold, which has the water inlet coming from the water pump, on the bottom side right where the bolt goes that ear is cracked and seperated all the way across, which when the motor is running will leak water, is it possible to get water in the oil through this? This is my first boat, and I know nothing on them. Thanks for the help in advance!!
