Tilt is not working
GMCarder
I am working on a OMC Mercruiser 1979 engine currently. I just got the boat yesterday and the person I got it from said the boat has not been used in over 2 years. My question is that I replaced the battery in the boat and I tried several things, one I tried the tilt but nothing happened except for a click when I push the tilt down or tilt up switch? What is wrong with the tilt? What do I need to check or do? I'd appreciate any help!
GMCarder
Re: Tilt is not working
The click noise by the way came back from the motor...sounded like it came from the solonoids?(i think thats what they are called?)
OMC Mercruiser
You can Only have 1 or the Other............<br />2 Very Different Companies,+ Concepts............<br /><br />If it's Black, there might be Some Hope..........
GMCarder
Sorry, the engine is a 79' OMC. Thinking two different things at the same time. Also it is white on the outside blue inside the boat. Any ideas?
