I managed to start this motor with the use of a couple of jumpers to cause the start solenoid to operate but hate to permanently jumper out anything without knowing what safety device I might be affecting. I have the original owners manual and Clymer's 1.5-125 HP 1956-1972 Outboard Shop Manual and neither show a wiring diagram for this motor. The solenoid is actuated by two white wires, one comes from the start switch and the other goes into a cable along with two black wires into the motor...you would suppose to a safety device of some sort. The black wires terminate at the round object that looks like it might be a horn or air pump. The white wire goes to a small metal pill like object that might be a mercury or other type switch with a second black wire leaving. There is no continuity through this switch regardless of position (it's located on the throttle shaft and rotates with it)
Any help or suggestions greatly appreciated
Today I decided to change the lower unit oil. Mostly water.. (prolly from yesterdays starting experiments) and a few gobs of black oil
