Trim wont go down
wroesten
Hello,
I just dewinterized my boat and was unable to lower my lower unit.It is a 2007 bayliner 4 cylinder i/o...i have attempted to bleed the lines, grease the cylinders and i know the pump works....I also disconnected the cylinders and they would still not move even when removed from lower unit.....any advice???? the fluid is full and clean!!!!
Thanks!!!!!
dingdongs
Re: Trim wont go down
does the pump work when hitting the down trim.it may work when hitting the up button and this will point towards the solenoid.can try taking a live direct to the green wire on your trim.if it works solenoid needs replacing.a quick memory reminder blue wire =sky/up and green wire =grass/down
wroesten
if the pump squirts oil when bleeding wouldnt that mean the pump was working?
