Re: laminating transom
You can do it either way; what kind of resin are you using? (polyester or epoxy)? If it's poly, I would seal each mounting face with a couple of coats and let it cure. Then sand it with 80 grit to scuff and level the surface then laminate the two halves together with a layer of 1.5oz mat between. If epoxy then I would still seal each face with a coat, let it tack up and laminate the two halves with epoxy and filler (Ex: If you're using West System, I would mix in some 403 filler for the lamination) and either clamp or screw the two halves together for curing..
