Painting topside with rustoleum
grampsrv
Aluminum boat primed with Marine Zinc Chromate, Had read about possibly using Rustoleum as a top side paint.The boat is used in both salt and fresh water.Would this be an alternative to Interlux Brightside Topside.Have used industrial grade rustoleum on other projects just not sure of durability on a boat.Would I use the same industrial grade that I now use on other projects or is there a Rustoleum Marine paint.Just put 2part epoxy on the bottom.(VC Performance)
