retiredfornow
Thread starter- Joined
- May 9, 2011
- 355
Bought it 4 weeks ago, it came with the boat I was wanting. Put a power pack in and it fired right up after new plugs installed. Put kits in carbs, clean as a whistle. VRO pump leaky, so I put in a regular fuel pump and did away with the vro pump. Did the link and sink, new fuel lines, new fuel line pump bulb. Starts and idles fine, and in the water, just past fast idle it falls all over itself. I can manually baby the carb linkage to get it to rev and once it "cleans out", it revs up. Drop it back to neutral for a minute and it will not take the throttle. With the motor off, and the control handle all the way on, the advance is against the stop and the throttle roller lines up with the lower (shorter) line on the cam. It revs just fine on muffs on land by just moving the carb linkage, in neutral. All 3 cylinders have 100 psi compression. Beyond me now. Seems like it's flooding out or the spark is behind. I'm at the end of my knowledge, wife keeps giving me that "I told you so" look. Any ideas?? HELP!
