Re: Darn, 303 Enfield stock cracked again, refurb w/ synthetic?
while finding another stock shouldn't be a real problem, you should definitely fix the old one anyway. Would be fine for a shooter. Spread crack open and clean well with acetone, use Acraglass epoxy, and drill stock and also use threaded brass pins with acraglass across the crack. Pre-drill the holes and then screw in threaded brass machine screws. After acraglass hardens, cut the heads off the screws and use a dremel and small bit to take the brass down below the surface of the wood. Then you can make up a little more acraglass to fill in the "dimples". The acraglass kit comes with dye so you can tint it. I fixed one like this (not an enfield) and unless I point out the repair, friends handling it have never noticed. Stronger than new. (this is a 103 year old Savage 1899, so I wanted to keep the original wood on it)
