I replaced the water pump on my 175 merc and now when going into F,N,R it shifts hard and clunks into gear. When In F prop will not spin CCW, when In N Prop spins freely and when in R Prop will not spin either way. Shift control was in F when I removed the LU and remained that way until I had the LU reinstalled. Shifting into reverse is exceptionally hard. This is also unrelated to the shift cables. Any advice would be greatly appreciated. Thank you!
