Hey I have a 1995 150 intruder.My regulator/rectifier caught on fire last week and I ordered a new 1. I put it in and now I don't have any spark the plugs.Can any one help.thx
Hi, you need to find out why the VR caught on fire and make sure there are no exposed wires because if you get wires grounding on on things you might have fried the Power pack as well. If you have an emergency stop landyard, disconnect the ground from that and see if you get fire back but just check for fire before trying to start. If you get fire then you will need to replace the stop switch for the landyard or your ignition key switch as well.
