Expidia
- Aug 26, 2006
- 2,374
On one of my last trips out last season I remember hitting a rock in a large bay that was not well marked on Lake Champlain. I knew the a path to the entrance of Burton Island was very limited, but was not paying attention to exactly where I was because I was going real slow, the GPS was reading a depth of 4 feet and had been through this same bay so many times.
I've hit rocks or stumps before and had to send the prop out to an online repair shop that charges like $28 to repair it.
I can live with paying for a prop repair.
But this time after that big clunk, there was no damage to the prop. So now at the beginning of a this season, I touched up some paint chips on the prop and when I went to put the prop back on I noticed it was binding very slightly against this black aluminum ring or collar located behind the prop. It's only held on by 2 bolts and then I noticed the top ear that the bolt goes through was cracked. When I took off both bolts I noticed the lower one was also cracked. They both fell right of the collar after I removed the bolts.
Bottom line was without those two ears intact, there was nothing holding the prop and the prop shaft into the lower unit. I pulled on the prop and the entire prop and shaft assembly pulled right out. And some accumulated water went right into the lower gear oil (that I changed at the end of the season). I was lucky to find this before splash down, because if I was in reverse the whole prop and shaft assembly would have popped right out and went to the bottom of the lake or river.
We need to be like a pilot inspecting his plane before take off. Before each launch! I'm glad I caught this damage before I got miles out on 10 mile wide and 132 mile long Lake Champlain, stopped somewhere miles from the launch, put it in reverse and I would have been screwed!
So I took the rig to my Merc authorized repair shop to order the part and said you might as well drain the water out and install the ring and refill the lower unit.
What ticked me off was the cost of this ring from Merc. They called it a carrier assembly. because the other end of the ring supports the prop shaft (hence the name carrier assembly). But $177 just for this part
12.50 for shop supplies
$7.82 Lower unit oil
$94 labor ($23 a 1/4 hour) I wonder how much a brain surgeon makes when he breaks it down to 1/4 hours
tax at $23.50
All tolled $323.
Sure I could have installed it myself and saved some money, but the part alone with tax was close to $200 anyway. This repair shop has done nice work for me for other motors I had them work on, so I didn't mind paying the labor. I was able to just leave the boat with them (went on to my real job) and picked it up a few days later after the part came in.
Sometimes, it takes a big bill to drive the point home how careful I need to navigate, so I don't hit anything.
When I'm on the Hudson River with it's 6-8 foot tide it can be easy to hit a stump or sand bar that was 6 feet lower when I passed over it only a few hours before. Chasing fishies into the shallows can be costly
Here is a pic of what looked to be a simple aluminum ring held on by the two bolts. But the other side since it supports the prop shaft makes it a unique and costly item!
Be careful out there. Use a navigational map or GPS with a Navionics chip or similar installed and if you have either of those, also . . . most importantly, pay attention to where you are . . . and do a walk around inspection before and after launching!
Here is the pic of what appears to be an simple and inexpensive ring, but wasn't!
tax at $23.50
All tolled $323.
