Re: Coil for a 3.0 volvo penta late model
You have the Delco EST distributor, stick with OEM coil, there is nothing gained by going to some type of hotter coil, but a lot to loose.
The 3.0L engines can be a bit of a problem with blowing head gaskets when timing and the ignition system aren't just right.
