lynnboy021
- Jan 27, 2008
- 553
i think i need a new esa cuz when it is pluged in i get no spark at all and then when i unplug it i get spark. i was looking online how to test the esa to see if it is good or not. i forgot where i seen it but a omc mech for 35 years said you can just unplug main cut out switch then connect one wire from the switch to a ground and another wire to the neg side of the coil. that will make it a merc setup he said, so will that work???
