It appears my stern drive is in neutral and will not shift into forward or reverse. I have checked the shift cable from the shift lever all the way to the stern drive connection and it is fine. With the shift ever in forward I can torn the propeller in either direction with no problem. If I turn it real fast in both directions there is a faint clicking noise Any ideas as to what the problrm might be would be helpful. It almost seems like the bearing on the propeller shaft is broken or a bad gear. Thank you for any ideas you might have. I have a 1993 ChrisCraft with an OMC Cobra stern drive.
Rich
Rich
