Re: Evinrude150V4
Pertaining to the one year old gasoline. There is good gasoline and then there's bad gasoline. Bad gasoline is "Stale" gasoline and there is no mistaking gasoline that is stale. No one needs to be taught the smell of stale gasoline, it is perhaps just one of the senses that we are born with..... a smell so offensive that drunken skunks have been known to head for the hills when encountering it.
Now, with that said, smell that gas. If it isn't stale, I'd suggest you use it especially with the exorbitant outrageous price of gasoline that is now being forced upon all of us by organized crime (need I explain that?).
New boat (to you)... Check the compression, with plugs removed check the spark, check the lower unit for water. The 50/1 mixture will not foul the spark plugs... use Champion QL77JC4 plugs gapped at either .030 or .040. One gap or the other may provide improved performance.
The VRO, whether to use it or premix is of course your judgement to make, however since the engine is a 1985 model and you really have no idea how old that VRO is, I strongly suggest that you either install a new VRO pump or switch to premix as follows.
(VRO Changeover Judgement Call)
(J. Reeves)
The VROs first came out in 1984 and have been upgraded quite a few times. In my opinion, back around 1988, they had perfected them but I think that they were upgraded even more since then. As long as the warning system is operating as it should, I feel quite at ease with them.
Some boaters have voiced their thoughts such as "What if that overpriced plastic horn should fail while I'm under way for some reason, and the VRO decides to fail five minutes later?" Obviously that would result in a big problem which really brings their fears into view.
The word "ease" is the key word though. If one has the slightest feeling of being ill at ease with that setup, then they should take the route they feel more at ease with. A judgement call each individual would need to make on their own.
(VRO Pump Conversion To Straight Fuel Pump)
(J. Reeves)
You can convert the VRO pump into a straight fuel pump, eliminating the oil tank and VRO pump warning system, but retain the overheat warning setup (and fuel restriction warning if so equipped) by doing the following:
1 - Cut and plug the oil line at the engine so that the oil side of the VRO pump will not draw air into its system. Trace the wires from the back of the VRO to its rubber plug (electrical plug) and disconnect it.
2 - Trace the two wires from the oil tank to the engine, disconnect those two wires, then remove them and the oil tank.
3 - Mix the 50/1 oil in the proper amount with whatever quantity fuel you have. Disconnect the fuel line at the engine. Pump the fuel primer bulb until fuel exits that hose with the tint of whatever oil you used. Reconnect the fuel hose.
That's it. If you want to test the heat warning system to ease your mind, have the key in the on position, then ground out the tan heat sensor wire that you'll find protruding from the cylinder head. The warning horn should sound off.
(Odd Soundings Of Warning Horn)
(J. Reeves)
Should the warning horn beep constantly when the key is turned to the ON position rather than sounding just a short beep as it should, do the following test.
Remove the TAN wire from the horn. If the constant beeping continues, the horn is faulty, in which case replace it. However, on the other hand, if the beeping stops, something has gone wrong with one of the sensor components at the engine, in which case start disconnecting the TAN wires that are connected to the various components (Heat Sensors, VRO, Vacuum Switch if so equipped, Oil Tank). Disconnecting a unit and having the beeping stop...... you've found the faulty component.
NOTE: The small black plastic horn that has a built in black ground wire...... The TAN wire must be attached to the terminal closest to that black wire. Otherwise weird things will happen.
(VRO Horn Warnings)
(J. Reeves)
NOTE: I retired around 1991/92. Possibly some of the later V4 engines and others may also incorporate a fuel vacuum switch that would enable a fuel restriction warning to sound as mentioned below, an unknown factor to myself.
1 - A steady constant beep = Overheating - The V/6 engines, possibly some others, have a fuel restriction warning which is also a steady constant beep.
2 - A beep every 20 or 40 seconds = oil level has dropped to 1/4 tank. (Late model engine = Every 40 seconds)
3 - A beep every other second = VRO failure, air leak in oil line, oil restriction, (anything that would result in a lack of oil being supplied to the engine).
NOTE - If the warning horn is the black plastic (overpriced) three wire type horn, the warning horn should beep once when the ignition key is turned to the ON position. If it does not, it is either faulty or someone has disconnected it (a stupid move!). At any rate, if it does not beep which indicates that the horn is non functional, find out why and do not run the engine until the problem is corrected.
