Hi
I have a 1963 seahorse 40hp Johnson , my question is this if i measure my transom it is 19 inch from top to bottom and i did measure the shaft on my motor it is 18.5 will it make a difference for my motor performance since i read that you have at least 1/2 to 3/4 inch above the bottom of the boat. cause before i put the new transom on i want to make sure that if i need to adjust something it is now cause if i cut it to low not good cause you cannot add , they say it is always better to cut some off than add some on. Is this right???
