recently the power trim system on this older boat (1987 Mercury 150 XR2 Black Max) has started to leak and the fluid is a milky red indicating water in the system. Since the water is brackish I want to drain the system asap and get the water out. The leak is at the top seal of the reservoir on the right side where the two metal pieces come together. The trim and tilt still work.
How do I drain this system and flush it out?
Where this is leaking, what seal is most likely shot?
Just 6 months ago I had added type F fluid to top it off.
thanks
thanks
