tidmarshsmiths5
- May 4, 2011
- 2
15 1/2 ft War Eagle; Wide aluminum boat with decking, carpet and 1 person powered by a 1989 9.9 Johnson...the question is how fast should she run?
IF that motor can plane the boat out then you should get about 15 to 18 mph. The problem with a 9.9 on a 15ft boat is the motor can't develop enough horse power in the lower rpm range to get the boat up on plane. Your boat is most likely rated for a 30hp or more motor. So with a motor at less then 50% of the hp rating don't expect to much.
I did a little research on War Eagle boats. The 542 model is 15ft-3in x 62in wide and rated at 25hp. The 548 model is 15ft-3in x67in wide and rated at 40hp. With either boat the 9.9 motor is still below 50% of the hp rating. This might be OK on a lake that has a 10mph speed limit or so. But, The one problem with being under powered is when you load up the boat and need to cover some distance. If this is the case then a 25hp motor might suit you better.
