whats the best matierial to make a new transom? and what tool is best to cut through fiberglass to expose old wood?my boat is a 1977 glastron t166 sportster 85hp outboard.thankyou.
No matter what wood you use make sure you seal it good with epoxy resin before you you start installing it.
once the old is out and the area cleaned up,do i have to adhere the new wood into the transome?
hopefully the old wood can be used as a template?
CadwelderI personally use marine grade plywood,
Cadwelder
Where do you get your plywood from in the Charlotte area?
Bart
thanks so much for the seacast tip! thats the best idea for transom repair scince sliced bread! i never herd of such a product. i checked it out on the web and will soon be getting a 2 gallon pail. it'll cut down my repair time conciderably. thanks again.
