redraider08
- Jul 13, 2009
- 20
Hey guys, i have a question about an exhaust manifold problem on a Volvo Penta AQ131. First a little background. About 6 years ago my uncle was given a 1989 Barrette with a volvo penta AQ131D. When my uncle got the boat we cranked it up and took it out. It started fine but would only get up to about 3000 RPM. The guy that gave the boat away said he had a friend work on the carburator and he might have not adjusted it correctly or might have not rebuilt it right. So my uncle just parked the boat and it sat for about 4 more years as he did not want to spend any money on the boat. 2 years ago we tried to crank the engine and it was locked up. He then pulled the head off and found one of the pistons locked up. He soaked it with oil and was able to free the piston. He started trying to figure out why the piston was locked up and pulled one of the exhaust manifolds off. He found it was very rusty and a hole inside the manifold and assumed water got pushed up into the valve and in the cylinder causing the piston to freeze.
Now my uncle said he would give me the boat if i wanted to try and fix it. He currently has the exhaust manifold pulled off and the heads pulled off. Would a hole in the exhaust manifold cause the loss of power when running the boat years ago? Does it sound like a worthy project? If that would have caused the loss of power what else should i look for when trying to get motor running again. I have not looked at the engine in a while but he said the cylinder that was locked up had a little pitting. Thanks in advance for the comments!
As far as my experience with engines goes i am familiar with outboards as i have rebuilt my 1979 115 Johnson but have never worked on any I/O's.
