Running on muffs
Water comes out of the tell tale strong after about 1000 RPM
At about 800 RPM not water but occasional sperts of water with steam
Normal or not.
Thanks
This is not normal. Your motor will over heat if you run it like this sounds like you are not getting enough water pressure from your pump time to change the impellor and pump.
