I have to replace the sea water pump on a mercruiser mcm 5.7 v8 alpha one. What are the steps? I can just pop off the trim rams and drop just the lower half of the outdrive like and outboard lower unit right?
ok. thanks. that is the way i thought. pretty simple drain oil pull six bolts and she drops. then replace impeller reinstall unit fill the gear lube and check water flow. Thank you.
