'97 Johnson 115, ID on this part/piece
Cricket Too
Need to know what this missing piece around my fuel connector is. Had my powerhead replaced and this piece, which I assume keeps water from going inside, dissapeared in the process and was missing when I got it back and now it's wide open to let water in.
I'd rather just replace it and be done, I don't have the patience to go back to the place who put the powerhead on.
Any help on what it's called and where I can get it would be appreciated. If it's available here at iboats, I'll buy it here.
Thanks.
Cricket Too
Re: '97 Johnson 115, ID on this part/piece
Thanks RD, but that looks like a later model than mine, where maybe the fuel line can't be disconnected.
edfishing2
Could you temp use a rubber grommet and split it so to be able install
bob johnson
id say you need part number 37 not 32!!!!!!!!!! 32 is for 88 specials...you said you have a 115...right?
unless you are never going to hook up the oil injection ever again..
bob
Cricket Too
Bob, I have a 115 SPL, sorry should've been more specific. The engine doesn't have the VRO/OMS parts or hook up. Has PT&T but not the VRO, which kind of sucks, but not too bad mixing the small amount of fuel a 115 uses.
So I just have the standard fuel only connection.
Thanks.
